Its a radial.
Why not use 2.5mm² cable?
Don't really want to.Clipping flex to skirting is rough. Use trunking.
DO NOT DO THIS. The carpet will wear on the cable, and the skirting is not a safe zone for concealed cables.Why not use 2.5mm² cable?
Could do. Could stick it under the carpet or skirting.
Is there an RCD for the existing socket?
If not, you will need one.
Is there a reason why you can't do this in a more *ahem* "permanent" fashion?
Or possibly rearrange the room so the equipment is serviceable by an existing socket?
As you intend to clip flex to the skirting board regardless, why not use an extension lead as this is designed and approved for temporary set-ups such as the one you are planning?
