Hi guys i hope you can help. i own a smallholding and have had EDF install a 20kVA SP&N supply to a kiosk in my field and they have fitted a 100A fuse before my meter and i have a 100A switch fuse after the meter. Now my question is this, what size armoured cable (burried underground) would i need to run 100m to an outbuilding to give me the same 100A supply at the far end. I assume its going to be quite big but the cable coming down the pole seems quite small. And do i need a two or three core cable if i have an earth rod at the far end in my outbuilding.
thanks
karl
thanks
karl
