- Joined
- 27 Jan 2008
- Messages
- 25,002
- Reaction score
- 2,894
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
Seen a lot about battery charging using pulse or step chargers and where speed is required these chargers clearly work well.
However where the battery is being used at the same time as being charged there are a few issues.
1) Either high voltage or voltage spikes which may effect equipment being used.
2) Equipment being used resulting in the battery being over charged as the thresh hold volts or amps which cause it to go to next stage is suppressed so it continues with a high charge rate after the 80% charged point has been reached.
By putting the load through the charger point 2) could be got around with the charger compensating for the load but my version of BS7671:2008 limits the voltage in a battery on charged in a caravan to 14 volt (A721.55.4.1) so to my mind battery chargers with higher voltages should only be used when the battery is not also being used.
I suppose a smart charger could be designed which swaps between two batteries one being charged and one being used but with main units can't really see the point as all that is required is a float charge as speed to re-charge not important.
However with solar panels and wind chargers finding a controller which does not have some boost feature seems hard to come by and speed of charging is important.
So thoughts please. Should one just say can't fit that it does not comply with A721.55.4.1 or is there a way to comply with A721.55.4.1 or does not complying with it really matter? It just seems that most solar panel controllers have either a ripple over 1.2 volt or a voltage over 14 volt so either way should not be fitted to caravans!
