So looking to get my house a bit more automated.
I have Hive active heating with Hive active lights around the house. But i don't like the hive plugs that they do. I don't like the plug in ones and ideally want a smart sockets that replace the old sockets. But I don't seem to find one.
So I am thinking about getting the SONOFF type WiFi switches that you can get, as they also seem to give you the option to monitor the power usage individually.
https://www.amazon.co.uk/Upgraded-C...3976&sr=8-1-spons&keywords=sonoff+pow+2&psc=1
Currently will be doing a big rebuild and all cabling will be replaced as they are 1930s cables which some have started to break down.
The issue with the SONOFF is that they will not work with ring circuits , so will need to convert to radial circuits.
It is not a big house. it is a bungalow with about 90sq m floor area. and upstairs is Dormer converted.
I am thinking aboud doing the following:
1) There are 3 bedrooms upstairs. There will be 3 separate radial circuits from the main CU using 2.5m cables. Each room will have max 5 twin sockets.
2) 1 circuit for all the lighting upstairs using 1m cables. All lights will be LED.
3) Kitchen will be ring main using 2.5m and no SONOFF on that circuit.
4) 1 circuit for all downstairs lights
5) 2 radial circuits for downtairs sockets ( 2 different areas).
i know for radial it is recommended to use 4m cable, but as I am dividing into smaller areas, with maximum 8 sockets on each circuit downstairs, will I be ok to use 2.5m cables?
The home network will be provided by a pair of Cisco 2960 POE switches, a Cisco WLC controller and a Cisco ASA for the internet monitoring.
Any thoughts?
Any thoughts?
