Hi
After reading this forum i have been doing some work on my dishwasher.
The story:
Anti flood activated, read the forum - took out dishwasher tipped over and loads of water came out of the base plate. removed the side because someone also said it could leak from the softner dispenser. Ran a cycle and could not see any leak! It did however did seem to start working again rather than coming up with the E1 error.
Now it does a wash ok and finishes with the 2 beeps as normal - about 5 minutes after this it starts buzzing as if the machine is starting to drain again - if i turn the machine off it stops obviously, when i turn it on again it works fine until its finished again?
Any tips?
Nigel
The story:
Any tips?
Nigel
