I have great hope as you got my dishwasher working last year - it had a E2 and E9 error code and just gave it a mighty clean out and it worked.
Anyway, this time I got a C2 error code. I cannot find any reference to this at all. I've cleaned it out, but it still won't work. The symptoms:
Turn on. C2 appears. If I hold down the go button, the side panel starts to fill with water. Then it stops. If I open the door there is a pool of water. I can manually drain it by activating the microswitch on the flood protection unit. I've taken the PCB out to look for burnt tracks, etc, but it looks ok.
Any thoughts on what I should do?
The model - DWF1 2. Which means I cannot reset the PCB (as it has those lever switches on the front).
Thank you~!
Thank you~!
