SMEG Dishwasher leaking through ring nut
5 May 2022
Australia
SMEG freestanding dishwasher (DWA6314b) has a leak into main compartment that is a (solid) trickle through the ring nut. Ring gasket seems ok so wondering if there could be a problem with the air break or if this king of leak is definitely with the ring nut and/or gasket (or something else)?
If leaks are passing between the thread and nut, try Locite 55
Thanks for the tip Bonni, I think I'll replacement the gasket as well and give the Locite a try.
Replaced the ring gasket o-ring thing, seemed to do the trick. Locite next step if the leak comes back.
