Dishwasher runs through the cycle but doesn't seem to be draining - is leaving water at the bottom of dishwasher, therefore have to clean this out before using again.
There is about an inch of water left at the end - doesn't seem to be draining anything. I've checked the waste pipe and that seems clear and the filter seems ok.
I'm not sure where the pump is or how to check if anything is blocking it?
