Hi, I had an E1 alarm (anti flooding/aquastop) on my Smeg dishwasher (8 years old, still looked new inside). I have pulled the whole thing out. and removed the plastic base. All hoses are well attached, eletricals looked ok too etc. I first found water leaking under the machine (onto the kictchen floor). Then I traced what the machine was doing and found it looked like to be designed like this. let me explain:
I have also found there is water inside the machine (under the bottom tray, where the filter is). Is this normal?
I have detached the water tank and inspected the process the DW tried to do:
1. It fills water to the tank (middle section) to a certain level for 2/3 times and empties the water out first, (there was still about 1/2 cm residue water in the tank tho.)
2. Then it tried to fill the tank with more water (into the upper component in the water tank), Then water will be (simultaneously) filled into some interesting looking water labyrinth at the very bottom of the water tank, which will then flood into a very small triangle where there is an open hole. The water will than leak out the "designed hole" (on the the bottom plastic of the machine almost touching the eletricals and onto the floor eventually) Because of this seemingly design flooding out, water will not fill up the top section of the water tank and the machine then detects this leak stops feeding water and push the water out the sewer again.
Then the DW repeats this process twice and beeps and E1 alarms comes up.
Diagnoses so far:
1. No obvious pipe leak, component brakeage anywhere.
2. DW draws and dumps water OK.
3. Found residue water inside the cabinet (where the filter is)
4. Found water leaks out water tank inside the component cavity and onto the floor. This looked like a designed process, part of Aquastop?
5. There is some electricals there looked like sensor and pressure controller etc.
6. Did not find "floating switch" etc.
Possible cause:
The cause of the water goes out of the water tank maybe caused by?
1. Pressure problem in the water tank?
2. Residue water in the water tank/base inside the cabinet?
3. etc
Please help me to DIY this. I have spent 6 hours on this. Thank you in advance.
Diagnoses so far:
Possible cause:
3. etc
