smeg dishwasher
17 Aug 2009
Nottinghamshire
Hi
I am having a problem with my smeg dishwasher. I get the error code E1 which according to the manual is "The anti-flooding device has been tripped" The only advice in the manual is to open & close the door, or turn the machine off and on (the old technical restart!!) Having tried this and also removing the filters and giving them a good clean, I'm still having the same problem. Any help would be greatly appreciated?
If the anti flood has operated you will find water in the base of the machine (under the part where you put the dishes)
you will need to empty the water out and find where it is coming from 'normally a leaking pipe or pump seal'
