The compressor or pipe work is tounch something.
Has it always done it, if so you should sort it under warranty.
If its just started, you may have pushed it back & its touching something.
or
The supports inside the compressor have failed, they cannot be replaced.
No it hasn't always done it. I'll check and see if it's touching anything at the back but pretty sure it hasn't been moved recently. Could it be something on top of the fridge touching the compressor pipe work?
