Hi I'm looking for some advice on a problem I've got - my toilet is directly above a utility room. If you are in the utility and someone flushes the toilet there is a smell of sewage in the utility. The smell only happens when the toilet is flushed and then goes away. Both rooms are next to an exterior wall and the waste pipe from the toilet run down the outside of this wall and goes underground right next to the utility room.
I'm not sure what could be causing this or where to get advice or help to solve this as its quite unpleasant as you can imagine.
Any help would be much appreciated - thanks
Steve (Notts UK)
Steve (Notts UK)
