I'm still planning my rewire, want to get it right!
In the bathroom, I was planning on installing a humidistat to control an extractor fan. I prefer this option over a timer fan because a) no fan-noise if someone gets up in the night and b) fan runs as long as it has to for eliminating humidity - should be less chance of a damp bathroom.
I've realised though... it doesn't do much for *ahem* smells! I've googled for "smellistat fan" but found nothing.
What I'm looking to do is find a way of setting the fan to go when someone's having a smelly sit-down. I've thought of a few possibles:
1) Use an "air quality" sensor - but I'm not certain these will work in that way
2) Use an occupation sensor with some sort of logic so if someone's in there for more than 5 minutes it turns the fan on and leaves it running for 10 minutes after they've left.
3) Fit a pressure switch to the seat so if it detects a bum on the seat for more than a couple of minutes it switches on the fan. (alternatively use a sensor on the door-lock)
4) A manual "boost" button that will get the fan going on full-pelt for 20 minutes - probably the simplest and most sensible solution involving just a timer and a momentary switch! I'd rather have something fully-automatic though.
Has anyone ever succeeded in solving this problem?
My house is generally the one everyone stays in after a night on the pop, so this is rather critical to my well-being... I never know when some pooligan is going to leave behind 8 pints and a vindaloo.
