We get the same so every now and again - I reckon it is the build up of crud. I put through the hotest wash there is and it seems to take the worst away for a while.
Make sure your drain hose lifts up as high as the underside of your worktop before it goes into the drain. Bad smells normally come from dirty water from the wastepipe getting back into the machine.
