Smelly hot water out of upstairs bathroom tap only
30 Oct 2005
Birmingham
Downstairs taps are fine, just the upstairs hot water tap pongs a bit.
I thought maybe some kind of nesting animal had got into the cold water tank in the loft but then I realised we had a new baxi condensing boiler fitted about 4 years ago and iirc the tank(s) in the loft are no longer used?
Any advice much appreciated :cool:
some new boilers are combis (no tank or cylinder) and some aren't. Mine isn't. Is yours?
best have a look in the loft.
if you have recently had plumbing work done it might be some material used by the plumber on jointing or soldering the pipes.
