As well as the BS7671 certification for mains powered battery backup smoke and heat detectors, my local building control are requesting a BS5839 certificat for new installs.
I have never issued these, although I have a pad from the NICEIC. The sticking point is the entries required for sound level test, ( my understanding is the test from a bedroom, should be > 65dba) as I don't have a meter. What do others use, can you hire the?
Is this test actually applicable to an LD2, Class D system :Mains powered, interlinked, with battery backup smoke x 1 heat detector x 1)
I have searched the forums and there is no info on this, do any sparks actually issue them ?
