Has anyone used this new smooth slippery osb3 board for laminating a GRP deck? Luckily I've got enough of the old 'rough' stuff for tomorrow's job but after that ....
Hi old
I moved over from GRP a few years ago due to weather restrictions ( Lancashire )
So I can't answer your question as I now use rubber. I do know the new boards are now a lot more waterproof than the old ones! I can't really see it being a problem though.
Thing I'm worried about is how well the resin will soak into the (fairly slippery) surface. The websites all seem to assume the older type- not sure whether T&G is now coated as well, I've always used 8 x 4 sheets cos cheaper.
I've got round the problem for tomorrow, think a call to my resin suppliers is in order (neighbours at one house have seen how well the GRP turns out on the bay, might be on a bit of an earner here
I used to use the 8x4 sheets , but ditched them when the smaller t&g boards became available due to very little wastage and speed of fitting, Plus easier to carry up a ladder!
As oldbutnotdead (I know how he feels!) mentions, all the literature suggests that a nice rough surface is preferred to aid baselayer bonding - so who on earth do we believe? Will other OSB producers be following suit?
