Hi, I wonder if anyone could give me some advice. I have been fitting a towel radiator, and I put PTFE tape around the radiator tails which were supplied with the Towel Rail. Connected it up, and the water was coming out of where the tails were inserted.
I took the towel radiator off, and took the tails out, and put new, and more PTFE tape around them, and tightened them up. Unfortunately, I overtightened one of the tails, and when I connected the Radiator back up again to the valve, it sheered clean off as I tightened the nut up. I now have the nut with part of the radiator tail, and the other piece of the tail is stuck in the towel radiator. I have tried to remove it with a hex key, but it is too small, and just turns, and I wondered if there is anything I could use to remove this piece that is inside, or will I have to scrap the towel radiator and buy another one (which seems a shame). Any help or advice on how to remove this, or if there is a particular tool I could purchase to remove it, it would be much appreciated.
Surely this must have happened to someone else out there!!!. If you would care to share you tips, look forward to hearing from you. Thanks in advance.
