Soak away
16 Oct 2006
London
Hi the condensate from my Keston system boiler situated in my cellar, emerges through an air vent at ground level into my garden (it's pumped via a saniflo). I want to put the condensate(32mm waste pipe), into a soakaway.
a) Is there anything that says how far away from the house the soakaway has to be situated and the depth?
b) I have seen on the internet simple designs for a diy soakaway opposed to buying a McAlpine. Will a simple 'home made' one suffice?
c) As it will be in 32mm pipe is it correct that I will not have to insulate the pipe where it is outside?
many thanks :)
many thanks :)
a) 500mm away from building probably similar depth
b) dont see why not, but why not just use the proper one anyway?
c) correct
many thanks :)
c) correct
And use limestone chippings to reduce the Ph level to something more neutral
some boiler manuals have the spec's and design in them
if you making it you self i would make 1m away from the house with the hole facing away from the house
rob884 said:
many thanks :)
c) correct
As always check MI's for boiler. Alpha now require them to be insulated. Other manufacturers may also.
I asked my corgi inspector if this was now the standard. What do you think his reply was? "Check MI's"
