We recently purchased a bungalow in west sussex which needs extensive works doing to make it liveable. This work is well underway and it's costing a lot of money so had planned to do nothing to the outside of the house till next year when funds allow. But having been down there in the rain I was alarmed but the amount water coming back out the top of the downpipes!
I ended up having to dig out the crazy paving in the front garden as it was a complete mess and just laid on soil. While doing this I decided to dig out the pipe to the soakaway, my neighbour informed me that the pipe used to be asbestos (it's been replaced into the ground with PVC pipe) so I took extra care not to damage the pipes. I eventually (after back breaking work) discovered the pipe and chiselled out the concrete around the pipe. I then removed the downpipe and it was full to about halfway up with muck, silt and dirt.
I decided at this point that it's probably easier to just lay a new pipe alongside the current one and dig a new soakaway. What pipe should I use? I will need a new downpipe into a shoulder into the ground (this section will be concreted back in) then a length of suitable pipe (approx 5m)_ to the soakaway.
I can't afford the plastic crate things for a proper soakaway so I am going to build a 1mx1m hole and fill with a load of the rubble which I have a lot at the moment. The ground is free draining chalk and a few neighbours have their downpipe just running straight into their garden with no soakaway but this looks a bit naff.
