Hello everyone. I am coming after quite a long time.
Would like some advice on how to provide drainage for 20m2 proposed car port.
I want to replace my existing concrete drive with paving bricks.the new regulations requires installation of a drainage channel and a soakaway for the surface water runoff from the drive which is 20m2.The soil is clay. The soakway is supposed to be 5m away from the house. This I think is just not possible. I've a depth of I've just 3.8m. The width of my semi detached house is approximately 5m. The semi on the other side with whom I share a common area leading to the back garden, has paving block drive with runoff into the public sewer as it was done some 25+years ago.
So I don't know where to put a soakway. Lots of houses on my street hv had new drives done and I can see a channel. All these houses hv similar depth ie. Just under 4m. The front area slopes towards the road.
The water from the roof drains into an existing drain.
Also what size of soakway do I need. Council Web site says 1m3. This seems too much. Also am worried about whether water will drain away as soil is clay. Also bit worried as car will drive over this drain so should it be then covered by a concrete slab.
