Electrical sockets over my kitchen worktops are about 18" above I want to lower them, is there a minimum level.
greymare said:Electrical sockets over my kitchen worktops are about 18" above I want to lower them, is there a minimum level.
Too close, IMO.mingmong said:And sockets should be at a minimum of 300mm if either side of a sink.
ban-all-sheds said:Too close, IMO.mingmong said:And sockets should be at a minimum of 300mm if either side of a sink.
1200mm sounds much better to me....
crichtons said:I'm in the process of re-doing my kitchen too, all leagally within part P/Local council notification etc. Can anyone clarify the minimum distance from a sink to a socket. I know that a bathroom is 1200mm to a socket and 600mm to a light switch from the shower/bath. Surely this can't be for a kitchen too. I'll only be able to get 1 socket in then.
And as for the 1200mm-from-a-sink thing, impractical in my old (1937) kitchen too! One side of the sink is 1000mm from one wall, the other 700mm from that one (small kitchen, big sink). The only places that are more than 1200mm from the sink are on the opposite wall or behind the door! Neither is sensible as a way to power the dishwasher...plugwash said:as for kitchens there are no specific rules about distance but there is the catch all that equipment must be suitable for its location. most spakrs seem to go for a minimum of about 300mm. more is better but can often be impractical in modern kitchens.
OOI, where did you get that "knowledge"?crichtons said:I know that a bathroom is 1200mm to a socket
Do you mean height-above-surface, or straight-line distance?mingmong said:sockets should be at a minimum of 300mm if either side of a sink
This is the Minimum requirement! further away is preferable
ban-all-sheds said:So you're saying (in fact you've said it twice) that the advised minimum height above the work surface is 150mm, or 300mm if either side of a sink.
Where did you get that advice?
