socket in a shed
7 Feb 2007
Wiltshire
I'm looking to put an RCD socket in my shed at the bottom of the garden just for the lawnmower or the odd power tool.
I'm aware of all the Part P stuff and will get a spark to do the final connections but my main problem is my consumer unit is at the front of my house and my garden is out the back. To run a cable from the consumer unit to the back of the house, although isn't impossible, is a nightmare job.
I have read of taking a spur from an existing ring main (provided its not already a spur) into an RCD unit (2.5mm T+E) then out of that, through the wall, into conduit under ground to the shed and then into an RCD socket.
Is that acceptable as I have a ring main socket right by my back door, real handy!.
Many Thanks
Mike
In general it sounds okay, I would be fitting a FCU before moving outside.
If you're going to be burying this cable then I would be looking at using metal conduit, SWA would be far far better.
It would need to be 500mm below the surface and protected in / by something.
I would ask a sparky to come and have a look, the preferable way would be to have a dedicated supply from your CU to another external unit in your shed.
How far?
Then you should be aware that you won't comply with the notification requirements of Part P that way.
What about running it on the outside of the house until you get to the point of burial?
That's 2 RCDs in series - not necessary and not a good idea.
That should already be RCD protected. If not, get it sorted, if it is (via an RCD for the circuit) you don't need another RCD anywhere for the shed spur.
