Personally I quite like the GET accessories I've used, and am a lot less impressed with MK than I used to be. Don't get me wrong, MK accessories will probably outlast GET in service, but I don't think that warrants them being three times the price of most other brands. Obviously avoid Marbo and all the other super-cheap tat.
Yes, you can say that the one which fails first is worse.
You cannot draw any meaningful conclusions about which is the more reliable make though.
failed how?
is that a fair comparison?
do the sockets that have failed get used more often? just the neons burnt out? are they left on for longer? have the same loads plugged into? etc etc...
if you have 2 sockets side by side from different manufacturers and subject each to the exact same load and useage then you can say that the one that fails first is worse than the other..
I like crabtree when it comes to switches and sockets and other accessories. Good solid screw connections. However I found recently their sockets have been changed from a round terminal for a square one which doesn't feel so secure. Anyone else found this?
