Hi I have a bungalow that I can fit flat spotlight downlights into which I see a lot of houses have done.
Question1: Can I get those as PIR? as when away from home want all lights around house to be sensor PIR, if not possible I can use up down light on wall.
Example can use these as can leave on or PIR mode but would mean cable showing on wall as oppose to soffit where I can hide cable inside soffit.
Question2: Can I use 1mm cable to loop through these lights from junction box or is 1.5mm more appropriate? I have a reel of 1mm ready to go.
OR should I add another switch altogether and keep PIR and on/off sperate feeds? and be done with it.
Thanks any help apprecaited!
Lutec Vienna Graphite Up & Down PIR Light | Wickes.co.uk
www.wickes.co.uk
