Soft Close Butt Hinges ?
20 Feb 2015
Lancashire
Hi, does anyone know if you can get soft closing butt hinges? I have 2 doors that are a little too thin to take the large hole for the modern soft closing hinge, and wonderd if there is anything out there thats flush mounted to both the door and the frame. Ive looked everwhare on the Internet but with no luck. Thanks.
I'm not really surprised. The "modern soft closing hinges" you refer to with the "large hole" sound like concealed hinges for lay-on doors (i.e. kitchen or bedroom doors). They require a 35mm diameter hole approximately 11 to 12mm deep (varies) in a 15 to 24mm thick door. Because kitchen and bedroom makers don't make thinner doors (they'd just never survive) I very much doubt that anyone would make the type of hinges you are referring to - there'd just be no market. You might want to consider using a conventionl hinge with a soft closer insert drilled and inserted into the cabinet frame or mounted in a surface mounting, like these or possibly these swisher ones
You could add a strip of 18mm mdf on the inside of the doors to allow them to take the soft close hinge.
