Hi. I have a hardwood front door in which the previous owner had a poorly installed catflap which I want to remove. I was thinking of covering the lower half of the door with 6mm softwood cladding with a softwood beading around the edge. Possibly mounted on a 3mm ply though I would rather keep things as low profile as possible. My question is, if I paint the door with a gloss, being the softwood is thin, should I treat the softwood with a garden wood preserve first? Will this effect the undercoat and gloss or is it just not necessary? Also, I was going to stick the cladding on with no-nails. Is this okay? Should I put some sort of sealant around the edge like an external caulk? If so, what sort of sealant is best?
Many thanks
Many thanks
