softwood door lining kit
17 Oct 2004
I'm just about to fit a softwood door lining kit (bought from Wickes). I'll use one of those moulded white finished panel doors so presumably loose stops arn't needed?
My question; the rebated section of this door kit is 20mm thick. Once I've rebated the hinge in, that'll leave me about 18mm for the hinge screws. The frame will be fixed to thermalite blocks.
18mm softwood for the hinge screws doesn't seem alot to me!
Am I right??
____________________________
Moderator
Moved from hi-jacked post
If its one of those moulded plastic abominations, I bet 2 tacks would hold it up! :D
nah a bit of spit and chewing gum! Seriously they will be fine
