going to be laying ptg softwood floorboards on a beam an block ground floor. so will be block floor, 75 mm kingspan then 2"by2" batons to fix flooring to .
i'm not sure if the 2 by 2 will sink into kingspan so was wondering if it would be advisable to use a sheet on 6mm plywood or hardboard on the kingspan to help spread the weight of the batons.
also whats the best why of fixing tg floorboards. i've been told that now its standard to glue each one when fixing seems a bit of over kill to me if the floor is well nailed or screwed down.
thanks
thanks
