Hello all,
I'm currently in the middle or refurbishing the downstairs bathroom which has an internal soil pipe. I need to either rotate or replace the current boss as the socket for the toilet is 90 degree in the wrong direction. From what I have read rotating it will most like result in breaking the seal as I think it is glued in place.
The only problem I can see with replacing it is that the bottom of the boss is actually below the concrete floor so cutting it would be very tricky.
The other option I have thought about is cutting the pipe halfway up and lifting the cut pipe and boss out of the floor and replacing with some new pipe and a new boss. I am not sure though of how the pipe connects to the drain below and would be worried about damaging anything during removal or replacing.
Any advice?
Any advice?
