I want to put 2 ensuites (next to each other) in on the first floor of my end terrace.
To join the existing foul drain the new pipes would have to go completely around the side of the house, (10m) around the corner and across the back of the terrace (another 4m) to join the existing stack at the back.
Am I right in thinking that I can its approx 25mm per metre minimum drop, ie I will have to ensure it drops around 1 foot before it gets to the bend around the outside of the house, and another 4 or 5 inches before it joins the exiting soil stack. Is it acceptable to merge 3 soil pipes, or do I have to take the new one to the ground and break into the mains sewer next to the existing pipe?
Also waste water from shower and basin, presumably that can join the new soil pipes, although obviously, not at the same diameter.
As I'm adding 2 new ensuites and associated bathroom electrics building control will have to come and have a look though.
Thanks in advance. for any positive input...
