Hello
My first post (I'm sure of many)...
Our toilet was blocked a while back and I replace the plastic/rubber connector - to remove the blockage I removed the horizontal pipe (behind a plasterboard wall) - this pipe emptied into the stack (at a right angle)
My question is.... is there some kind of connection sealant or I should use for the joint between the soil pipe and stack? I know the connector should remain with flex however we are seeing a slight leak on the right angle ???
Thanks in advance
Thanks in advance
