My house has 2 connections into the main foul drainage within 1m of each other and the idea is that 5 toilets will connect to both of these following an extension. I fell out with the builder that did it like this so I'm not sure what the exact plan was. I know that usually you would have one soil stack that sticks out of the roof or you have an air admittance valve but when you have 2 connections do you need 2 soil stacks or do you connect these 2 stacks together within the property and have 1 soil stack? One connection will be used for 2 ground floor toilets and the other will have 2 first floor and one loft toilet going into it.
