Hi all. I'm mid way through a bathroom renovation. As part of this I will be moving the T on the vertical 110mm soil stack down into the 1st floor void (its above floor level at the moment). The stack currently vents up through the loft and out of the roof. As part of this, ideally I want to remove the vent so we don't have it boxed in in the adjacent bedroom, as it take up valuable space. Ideally id like to reduce the vent size down to 50mm so it can be inside the partition wall which has 76mm depth. I would then terminate in the loft with an AAV. So my question is, am I allowed to reduce it down to 50mm just for the vent, or does it need to be 82mm waste, which i could achieve with padding the wall out a tad, but the 82mm pipe is expensive.
For info there will be 1 toilet, 1 sink, 1 shower and 1 bath all into that stack from the same bathroom. The other downstairs bathroom and the kitchen go directly into the ground, no vents.
