Hi all
I have a Flat (ground floor) its a converted ex shop, 75% of the floor is concrete and I have small areas of floorboards.
I started having a roller coaster flooring issue in my passageway, I initially thought this was just warped tounge and grove (covering the passageway), so I decided to lift the tounge and grove today, it seems the problem is actually a chipboard panel someone had fitted in the past in place of floorboards under the Tounge & Groove.
This chipboard panel had rotted and was swelling.
I have torn a section of the chipboard away and to my surprise the soil level below is about 3"-4" (yes inches) below the floorboards it looks as though even the joists are partly covered in soil.
Should I dig this deeper prior to fitting new floorboards?
If so to what depth?
Would I be right to assume whom ever layed the concrete floor has just shifted excess soil to another loaction under the floor?.
Or am I on the wrong track
Heeeelp!!!
Many thanks in advance
Kevin (Portsmouth)
Heeeelp!!!
Kevin (Portsmouth)
