Soil under floor space actually on the joists - Help
26 Jan 2005
Hi all
I have a Flat (ground floor) its a converted ex shop, 75% of the floor is concrete and I have small areas of floorboards.
I started having a roller coaster flooring issue in my passageway, I initially thought this was just warped tounge and grove (covering the passageway), so I decided to lift the tounge and grove today, it seems the problem is actually a chipboard panel someone had fitted in the past in place of floorboards under the Tounge & Groove.
This chipboard panel had rotted and was swelling.
I have torn a section of the chipboard away and to my surprise the soil level below is about 3"-4" (yes inches) below the floorboards it looks as though even the joists are partly covered in soil.
Should I dig this deeper prior to fitting new floorboards?
If so to what depth?
Would I be right to assume whom ever layed the concrete floor has just shifted excess soil to another location under the floor?.
Or am I on the wrong track
Heeeelp!!!
Many thanks in advance
Kevin (Portsmouth)
i would dig it out at least 18 inches to get it bellow the damp proof course
i would also be concerned that the joist may have been dammaged by the damp[from the earth]
The joists are damp but appear sound, Ironically part of this preparation (Tounge & Groove removal) is for a DPC course on my flat Beginning Thursday 9th)
Thanks for your advice - this soil issue is a total surprise to me, and I had no idea how deep is should be
Thanks again - appreciated
another point make shure the soil is below any air bricks to allow airflow
DPC guys say that I need more
I will check out the levels
Kevin
You may have got a bodge job there - joists laid on ground, boards nailed onto them - joist not supported by sleeper walls. One of the easier ways would be to dig it out and lay a solid floor.
