Hi folks
I have installed a solar heated geyser. There is a flat panel collector that is connected to the geyser via a small recurculating pump controlled by a geyser max "computer".
Further pertinent info: I have an off-the-grid home so there's no water-mains. Instead the home is fed with a pump from harvested rain-water. Nothing fancy: opening the tap drops the pressure which switches on the pump and water flows.
The problem which has me vexed is this: As the geyser temp reaches above 40degC, when the recirculating pump between the solar collector and the geyser switches on... for some reason there is a pressure drop in the geyser and it begins to suck air from the vacuum breaker.
This is a bit of a noisy affair and is a bit irritating. But nothing near as irritating as when we open a hot water tap later in the day and have water spitting and spurting at us until the bubbles are all expelled.
Now the thing is this: if, just as the vacuum breaker begins to such air, we open a tap and in so doing switch the mains pump on, then there is no problem. The mains pump pressurizes the system and the geyser sucks no more air.
What I don't understand (and don't have the experience to even begin to guess) is:
1. Why the recirculating pump switching on causes a partial vacuum to form in the geyser - and why only at temperatures above 40degC.
2. And why this drop in pressure in the geyser doesn't anyway trigger the mains pump.
3. And MUCH more importantly, how to fix this problem.
If any of you can help me with this I would be much obliged!
