Hi Guys,
Im new hear, and have read as much stuff on the old tinternet as possible, but nothing really answers my question.
With the old gas and leccy price going through the roof, and that im renovating my house. I was thinking about doing DIY solar evacuated tube thingy!
The thing is i realize they arent the best in the winter, but apparently the still work a little. So i was wondering how to hook up my existing sealed combi so i can get the best of both worlds, i.e. as much free hot water and heating as possible.
My idea is to get a thermal storage hot water tank, with two flow and returns. One set for the solar panel and one set to connect to the combi central heating flow and return, and not sure if you can get it but an immersion heater in the tank as well, ( a real belt and braces effort).
However i have read that combis should not have hot water pre feeding them. But with a central heating loop there must be a fair bit of heat in the return loop, so i dont understand this argument.
I am hoping in the summer the solar should heat the cylinder plenty to do all the hot water, and then in the winter for it to do some work to take the chill of it, and because its winter ( and the mrs) the heating will be on full tilt, so the combi will doing most of the work heating up the old thermal storage tank, consequently with enough hot water for all her baths.
I was then thinking of just not using the hot water part of the combi.
Does this sound like a completely stupid idea or vaguely sensible.
All comment greatly received, even if it is your a plonker.
Cheers
Adrian
Cheers
Adrian
