I am removing a radiator permanent from my kitchen, it has the drain valve as it is the lowest and end of system rad.....what is best to cap of the pipes please...a compression drain valve and stop end or soldered.
Thanks.
and if I go with compression are the JG Speedfit Drain Cocks OK, it says they just push on to the copper pipe with no tools needed....how does that work?
if you mean it has the drain cock because it is the lowest point in the system, it's a good idea to keep it. If there will (normally) be no flow in this pipe, because you have removed the rad, you might consider putting a full-bore cock on the end, with a 3/4" hose connector. This makes it very quick and easy to drain the system when necessary, and the fast flow will help wash out loose serdiment.
I fiited a washing-machine tee on mine. Some people say the heat will age the seal, but this would not apply in your case. Fit a 3/4" blanking nut on it so that it will not leak if someone accidentally turns it on.
btw it is very difficult to solder pipe that is not perfectly dry.
