Hi all,
After a lot of reading, and watching a couple of videos, I shelled out on a Rothenberger Super Fire 2 kit; the kit came with a can of MAPP gas.
I had no problems on a test, and capping an old electric shower feed went fine (after I flushed the toilets...) but I'm curious about how quickly one is supposed to get the connector/pipe to temperature.
The videos I watched showed people heating the cap/elbow for about 5 seconds before soldering, but the caps seem to hit temp after about a second or two of heat, and the solder gets sucked straight up. The joins seem good, and they don't leak.
The torch is pretty impressive when it comes to output, so I turn it down to the lowest stable setting I can. Is MAPP gas that much hotter than propane, or am I creating a bunch of potentially awful joins?
