- Joined
- 17 Feb 2006
- Messages
- 375
- Reaction score
- 2
- Country
This isn't really plumbing, but I'm considering plumbing materials/techniques.
Just finishing off 60 feet of fence. Looks good, though I say so myself. I used 4 inch posts, treated, concreted in. I want to protect the tops, which are cut square.
From the US I can get copper top things, but I thought about making them myself, out of lead.
So, get the thinnest grade of sheet lead (code 3?) on a 6 inch roll. Cut 6 inches off. Cut across each corner, fold an inch of each side down. But how to join the seams?
I've got an electrical soldering iron. That just ain't gonna do it, is it?
I've got a propane torch. Would that, and the lowset melting point solder I can get, do the job? I'm assuming that this is going to be a case of enough heat to melt the solder, but not the sheet lead.
Presumably I'd neet to flux the sheet and so on. Or would I, as this isn't the usual copper pipe work that I've done so successfully in the past (like, er one joint!).
Any ideas welcome, thanks
