Though not a pro, I am a very keen DIYer, with lots of experience. Believeing that 'copper is proper', I like to use copper pipe in my projects with enfeed fittings.
Sometimes, I get a problem with getting the solder into the joint. It seems to just run down the outside of the fitting/pipe and occasionally I get leaks. For some reason, tees and 22mm couplings on vertical pipes seem to be the main problem joints.
I always clean the pipe, and apply a thin even layer of Powerflux, and heat the fitting.
On a tee, should I just hold the flame on the middle of the fitting in one place, or direct it at each branch seperately that I am putting the solder into?
Is it best to heat the highest branch first, then do the lower branches last?
Is a cooler flame better, or should I get the gas on max and heat the fitting as quickly as poss?
Is it possible to overheat a fitting, and would this stop the solder flowing in?
Any tips appreciated!
