I am installing an Aga type solid fuel cooker with boiler + rads and indirect cylinder. I want it to be pumped CH and gravity DHW. At first I was going to try and manage without any motorised valves but it looks like this could result in a circulation of water through the rads and indirect coil without going through the boiler! I would like the pump on the return as it gives it a bit lower operating temperature. I wondered about a 2 port valve on the DHW coil circuit, connected to the pump. It would need to shut off the DHW coil when energised and open again by spring action in the event of a power cut. Does such a valve exist? The ones I have seen appear to be open when energised.
The alternative seems to be a 3 port diverter valve used instead of a tee on the return pipe to the boiler. Again when energised by the CH it would divert the pumped return into the boiler instead of the gravity return from the cylinder. I could have a pipe stat on the flow pipe from the boiler so that the CH cuts in above a certain boiler temperature. I have done quite a bit of plumbing over the years but have never used motorised valves so am not really sure what they can and can't do.
