im hoping someone can diagnose our heating system!
we have a solid fuel stove which does the heating and hot water. The way it is plumbed from what i can see downstairs radiators are ran via a pump, and upstairs are done by gravity. Downstairs work fine (there are only two rads on the pump). Upstairs is a different matter. There are 4 rads upstairs, only 2 work, the bathroom and a bedroom which seem to be connected to each other as they are backed against each other on the same wall. The other two come on only sometimes and when they do are not very warm at all.
Ive checked im burning correctly and at the right temperature.I have all the stats on the pipes set correctly i just cannot understand why they arent working. Ive bled them all, ive opened all the valves up and im out of ideas!
Any advice would be much appreciated!
