Solid hardwood flooring vs floor boards
28 May 2008
Shropshire
Probably a silly question, but bear with me.
I'm looking to replace the old chipboard floorboards upstairs in my house. I was thinking of installing plywood floorboards and then putting laminate over the top.
But i'm thinking it might cheaper and better to just install solid wood floorboards over the joists.
Is the solid wood flooring you see advertised at various flooring companies suitable to replace floorboards (IE load bearing) or is it designed to sit on top existing floorboards?
Can anyone recommend a good supplier of these types of materials?
Only 18mm T&G hardwood floors can usually be used nailed straight on to the joist. But check the manufacturers specification, max centers etc...
Why take the old floor up?
If it is ok condition leave it down and thicken up your floors timber is a great insulation
Yes, at least 18mm, at least long enough to connect with at least 3 joists which shouldn't be further apart than 35 - 40 cm
Cheers for the replies.
The old floor is chipboard and is in poor condition. Pretty much every floor board creaks. I'd assumed laying new flooring over the top whilst easier wouldn't get rid of the creaking.
So 18mm tongue and groove it is then...
