Hi, I'm replacing 4 internal doors and would appreciate some advice on whether to get solid or veneered oak doors. Obviously, the veneered oak is much cheaper, but the doors are going to need adjusting to size and I know there's a limit to how much you can cut off a veneered door. I'd have to buy the standard 1981mm height, but they'd have to be trimmed, at the smallest door, to 1940mm. Is that too much to trim off a veneered door? I suspect so, in which case solid oak would be needed. The concern I have about that, is that I know they're very heavy and need 3 hinges, but I'm not replacing the pine frames, so would that mean having to chase out 3 new hinge areas, or would a carpenter use the original two and then add a third? I don't want the frames to have loads of gaps, as even though I'm painting them it's look a mess. Thanks in advance for any advice.
