- Joined
- 1 Oct 2019
- Messages
- 52
- Reaction score
- 0
- Country
Hi All,
Looking to install 22mm x 270mm solid oak kiln dried floor boards, in an Edwardian property.
So suspended timber joists with a dry over-site below, good air flow.
We plan to take up the existing pine floor boards to replace with the Oak.
The floorboard suppliers suggest a 1000 gauge plastic membrane laid over the joists, lapped up behind the skirting boards and screwed secretly through the tongue.
One installer suggests 18mm TnG ply laid down first then the boards fixed as above.
Another suggests that P5 TnG chip boarding would be ok again then screwed down through the tongue.
I have also seen the stick down rolls which would also act as a membrane..?
I realise that expansion is not to be under estimated, along with the moisture levels..
What moisture levels would be acceptable below the floor area?
All advice greatly appreciated..
