Hi
We've recently bought a house which has an extension to the back. This extension is single brick with a flat roof.
It currently has a stud wall construction around all four walls, covered with plasterboard. It has pipes with stopcocks and has the gas meter in one corner. It has old polystyrene insulation. It has a concrete floor.
We want to insulate it properly.
From reading so far it appears we want to remove the old plasterboard, fill the studwork with Celotex style insulation, then a vapour barrier, then plasterboard, then skim. At the same time we need a DPC on the floor before any floor insulation.
We will put insulation above in the future to have a warm flat roof construction when the roof needs doing. What's the best thing to do in the meantime. Just put a vapour barrier in but no insulation?
Also we need access to the stopcocks and gas meter. How do we keep this access and insulate the room properly?
Many thanks for any replies.
