Solid wall insulation
19 Aug 2008
Yorkshire
My bathroom has solid walls which i would like to insulate (north & east facing brrrr). What's the best way to do this. Somebody told me that I have to be careful what I use as plasterboard or similar will get damp. We already get mould on the ceiling! We intend to tile the walls after.
Hope somebody can help - thanks
Flexible Thermal Linings and almost all brands of thermal boarding provide extremely high thermal efficiencies in regard to thermal insulation. Therefore, it is possible to achieve a very high level of thermal performance using relatively small thicknesses of insulation (which can be a major asset for small dwellings).
You can also have insulation injected into your wall cavity, this sounds costly but you can apply for a grant to help you with he payment of this as it is saving energy (good for environment etc..)
I suggest you just use google.com to find out how
Source: www.nationalinsulationassociation.org.uk
You can use insulated plasterboard straight onto your bathroom wall, if you are tiling it. The tiles and adhesive should provide enough protection to the plasterboard to prevent moisture settling in.
If you have serious moiture problems, use a thin PIR board (the likes of celotex, kingspan, etc..) and use a tile backer board or cementitious particle baord on top. I believe you can get insulated cementitious particle board that are used as soffit boards that maybe you can use in your bathroom.
