Hi all,
I'm in the process of performing a much needed house makeover and I've run into something that has split opinions a bit. The upstairs of my house has pine floorboards, the bottom concrete; I want to put solid wood flooring in the living room and bedrooms (and possibly kitchen, subject to debate).
The living room has a concrete base so will simply be a case of underlay -> flooring. The upstairs, however, I'm not sure about.
Should I put underlay and then the flooring directly onto the floorboards, which would result in the floors being raised by ~2-2.5cm? In this scenario I imagine I'd have to plane the bottoms off the doors. This creates the problem however that we aren't going to put new flooring on the upper landing necessarily, so there might be a strange change in floor height (or..? suggestions welcome).
Alternatively, should I take up the floorboards in the bedrooms and replace them with something like MDF -> underlay -> flooring, in order to retain approximately the current floor height?
Thanks,
Ollie
Thanks,
Ollie
